Ensures that USB 2.0 storage device can be safely removed from the switch.
N/A.
After the switch writes to a USB 2.0 storage device, and before you can view the contents on the device, you must ensure it is safe to remove the device from the switch. Use this command to prepare the device for removal. After you run this command, you can manually remove the device.
Note: The destination of debug core dump is still configured to memorycard. If a memory card will not be present, it is recommended to use "configure debug core-dumps" to change the core dump destination.
For more information about removing a USB 2.0 storage device, see the hardware documentation.
To access and read the data on the card, use a PC with appropriate hardware such as a compact flash reader/writer and follow the manufacturer‘s instructions to access the compact flash card and read the data.
The following command prepares a compact flash card or USB 2.0 storage device to be removed from the switch:
# eject usb
This command was first available in ExtremeXOS 11.1.
Support for USB 2.0 storage devices was added in ExtremeXOS 12.5.3.
The memorycard was deprecated in ExtremeXOS 30.7.
